AC compressor
NinoB
2.2 16v
AC compressor
Post by NinoB »
Morning pug gurus..1. I realized that my compressor turns on 30seconds and turned off 20seconds..which is very annoying the period of turning on and off is too short depite the car is cooling..2..sometimes if I on the AC it makes a sucking sounds from the blower before it start cooling..3.. Meanwhile sometimes if I on it the compressor keep struggling to turn on, it takes like 20seconds b4 it pick up..please any suggestion on what is the problem? Is it shortage of gas or my thermostat or what???
gumby6371
Re: AC compressor
Post by gumby6371 »
My limited knowledge of AC systems tells me that the compressor won't kick in at all if gas is low or if the thermostat is telling it it's not needed.
If it's not kicking in when needed I'd check the electricals to the compressor first, could also be a sticky clutch which could be tested by applying 12 volts to it and see if it engages.
I'm sure some more knowledgeable forum members will be along shortly.
NinoB
2.2 16v
Re: AC compressor
Post by NinoB »
Is cooling and the compressor kicks on but what disturbed me most was the time intervals( on and off) it pisses me off ..why will the compressor will be on lessthan a minute and goes off all within a minute..I dunno if someone is experiencing thesame issue with me?
Re: AC compressor
Is your radiator fan working? It should be running whenever necessary to keep the condenser pressure down, if it can't control the pressure it will disable the compressor instead.
D4B
Re: AC compressor
Post by D4B »
NinoB wrote:Is cooling and the compressor kicks on but what disturbed me most was the time intervals( on and off) it pisses me off ..why will the compressor will be on lessthan a minute and goes off all within a minute..I dunno if someone is experiencing thesame issue with me?
I think I might be having the same problem with my air con, but yet to try a re-gas.....
My other Peugeot was a D4B
NinoB
2.2 16v
Re: AC compressor
Post by NinoB »
@doggy Yea the radiator fan is working! I can hear the sound of fan switching to higher speed sometimes
@D4b do u mean I should replace the gas or u mean I should just top up?
Which gas is ever better and recommended for peugeot?
D4B
Re: AC compressor
Post by D4B »
NinoB wrote:@D4b do u mean I should replace the gas or u mean I should just top up?
I meant that I should have MY car re gassed and then see if has improved, but perhaps my car is suffering the same symptoms as yours.
Don't know much about gas types, but is it R134a?
No doubt someone more knowledgeable on these things will correct me if I'm wrong....
Good luck
NinoB
2.2 16v
Re: AC compressor
Post by NinoB »
Good luck
I used "Honevweii genetren 134a refrigerant, gross weight 390G" I dunno if its really good for 406..I dunno how many can I shud used, well I only used 1 can 390G..I dunno if its less!! Any1 with ideas on the quantity to be used?
hammerman
Re: AC compressor
Post by hammerman »
The compressor will spend a certain amount of time on,then it will switch off for so long,then back on again.This i belive is to stop the pump/compressor from over heating.My a/c also makes a sucking noise from the face vents when switched on.Always has done.If you have nice cold air coming out,i would`nt worry about it.If its low on gas,then the system will still work,but the cooling effect from the vents will get worse,untill the system still works,but no cool air comes out from the vents.After that,once the gas level gets to a very low point,the system will not switch on or work at all.
I know this,because i had this last year,& i had it sorted 2 months ago,& its done the same now.Its been into a/c specalist today for a drain & leak test,& i have a leak from the condensor rad.
2003 Hdi Est SE
