Hi Everybody,
I have a question regarding the DPF/FAB removal from the ecu of a Peugeot Partner from 2007 enginecode DV6B, is this possible with for example a Galletto/MPPS/KWP2000 flasher cable?
and second question, is there a preferable way to physically remove the filter from the DPF?
I am sorry if i posted in a incorrect board forum
Regards
DPF/FAB removal Peugeot Partner 1.6HDi 55KW
Re: DPF/FAB removal Peugeot Partner 1.6HDi 55KW
Afaik no you cant do it with a Galletto. It can be done via the obd but most places will tell you it's a bench job. I'm not sure what your filter is like. My 307 filter splits into 2 halves and then you can gut the filter and put it back so it looks standard.
I defapped a 2006 307 1.6 with the galetto without any problems, i did have to save the original ecu file and send it to someone to remove the fap feature it worked fine on that car, although the 307 had a bad engine before this remap and its still bad using oil and no throttle response
Which ecu?FarmerPug wrote:I defapped a 2006 307 1.6 with the galetto without any problems, i did have to save the original ecu file and send it to someone to remove the fap feature it worked fine on that car, although the 307 had a bad engine before this remap and its still bad using oil and no throttle response
I think it was a bosch
