service reminder
NinoB
2.2 16v
service reminder
Post by NinoB »
I just service my car(EW10) ..fully change the engine oil to (total quartz 5000), change the filter too..after doing that successfully, then try to set the reminder..when I set it , it shows me 20000 for the next service I was like :shock: what went wrong? Is supposed to be 12000, but why mine is high ? Any ideas on how tow bring it low as 12000 or less ?
Rolebama
Re: service reminder
Post by Rolebama »
Just a thought, but 12000miles is near as dammit 20000kms. (?)
1998 2.1 GLX TD
NinoB
2.2 16v
Post by NinoB »
The car is UK , and before it was showing 12000, so after changing oil and filter I reset the reminder , then it show 20000..I dunno if pp2000 has an important role to play on this issue!
You can change the 'counter' display whilst resetting the thing.....I think you reset it....then press again to change the interval to what you need. The mileage counts down in multiples of 50 I believe.
NinoB
2.2 16v
Post by NinoB »
Thanks Willy, but can U give me a details procedures on how to do it?
Because if I hold the counter button , on the ignition till it count down from 10 - 0, then off the ignition , then on it again it will come back to 20000 again :(
gumby6371
Post by gumby6371 »
Rolebama wrote:Just a thought, but 12000miles is near as dammit 20000kms. (?)
I'd agree with Rolebama on this one, sounds like it's changed to KM, if so it will still be accurate just a little confusing.
Planet should change it back tho if you're that bothered.
NinoB wrote:Thanks Willy, but can U give me a details procedures on how to do it?
I can't quite remember how, but it is changeable, perhaps another member can help.....anyone???
NinoB
2.2 16v
Post by NinoB »
Anyone please?
Have you seen this by our member Farmerpug:
-S242FaJaAg
I am sure you can change the counter by pressing something else in the sequence.
NinoB
2.2 16v
Post by NinoB »
Welly wrote:Have you seen this by our member Farmerpug:
-S242FaJaAg
Did u attach something? Is just blank I ddnt see it...but is like a youtube video..can u send the video to my box or the address...this my mail [email protected]
benczuk
Post by benczuk »
NinoB
2.2 16v
Post by NinoB »
I saw this video, but is only for resetting the service reminder and deactivating using pp2k, BUT NOT REDUCING THE DISTANCE (like mine just changed from 12000 to 20000 while am trying to reduce it back but I cud not)
