car won't start
- 1.6 8v
car won't start
hello, recently had a problem where by the ignition key got jammed and couldn't turn car off so I ordered and new ignition barrel with new blade from dealers, fitted it today and car started up 1st turn then turned it off and the immobilser light came on and won't start at all now and it won't even lock/unlock with the key fobs. any ideas anyone. thanks
Re: car won't start
Was the new blade fitted to the original key fob? If so it should just need to be re-syncronised.
Currently frustrated by: 2002 2.2HDi Executive Saloon
Re: car won't start
Put your key in the ignition and open the drivers door, you should get a 'bong' and a message on the display. If not then the car doesn't recognise the key.
As mixman said, is it the original key case with transponder with the new blade spotted in?
As for the locking, if the car recognises the key, then put the ignition on, press and hold the lock button on the key for 10 seconds, then turn the ignition off. Try the remote locking while you are still in the car to check its worked....
- 1.6 8v
Re: car won't start
Ive got it working now, didn't have blade aand transponder together in keyfob. took old blade out and put new blade in old key fob, but now Im stuck with one key for starting it and one key for doors. I thought the dealers would have sent me the new barrel set up to work with my old key blade. oh well. atleaset I can get to work now lol
Re: car won't start
You can still use your old fob ( with new blade ) to unlock the doors, giving you a spare door key to stash somewhere in case you get locked out....
- 1.6 8v
Re: car won't start
yeah gonna get another copy of that new blade and replace the old blade in the spare key so Ive got 2 keys with 2 new blades then get a old key case and put the old blades in that one so Ive got a back up key to manual unlock doors. cheers for your help.GingerMagic wrote:You can still use your old fob ( with new blade ) to unlock the doors, giving you a spare door key to stash somewhere in case you get locked out....
