Mileometer/Tripdisplay Problems
Old Smokey
Post by Old Smokey »
Hi Guys,
Driving around today in the 406 & mileage reading & trip display have
gone blank ! Idon,t know what,s wrong but i do have to hand a spare
set of clocks.It,s easy to change them over so if i put in the new clock
set what mileage will it read ? Is the mileage recorded in the ECU or
in the speedo head itself ? Anybody ?
It's not something daft like the backlight bulb simply dying is it? :)
Re: Mileometer/Tripdisplay Problems
Old Smokey wrote:Is the mileage recorded in the ECU or in the speedo head itself ? Anybody ?
I think the answer to that is both, and if you change the clocks the computer adds the mileage from the new clocks to the mileage in the car's ECU and you end up a very high reading :cry:
Then again I might have dreamed that....... :?
Benner
Post by Benner »
I have to agree, Id check the bulb before you do anything. This is very likely to be your problem.
jameslxdt
Post by jameslxdt »
its most likely the bulb, and Dai you are almost correct, if its a D9 then if you put a different set of clocks in then the BSi adds the current mileage to the mileage of the clocks fitted
Old Smokey
Thanks for the replies.mines a D8 2.ITD so i don,t know about the adding on
mileage if another clock is fitted. Anyway clocks out then asap & we,ll check the bulb first....cheers...
Try shining a torch at it from a variety of angles at close range. If you can see the numbers it's definitely just the bulb and you can relax :)
muffindell
2.2 16v
Dash bulbs
Post by muffindell »
It's always the backlight bulbs that go in my experience. Mine used to go every 6 months or so, which got me wondering if there are different quality bulbs that last longer?
