Mine is a 2000 2.0 Hdi. I followed the suggestions in this ;
http://s1101.photobucket.com/user/406oc ... 7734483006
And upon starting and going to put the drivers window up, it would move about 10mm and stop, lift and repress the switch, repeat.................
I repeated the disconnect procedure, but with the window fully up, disconnected the ground lead, refitted and back to normal. I'll note that the auto close on the drivers window sometimes closes and immediately reopens, so maybe the problems are related.
Electrics.........
