Hi there Crazy Pete,
I'm very well thanks,
You'll need to jack up the front end, place on axle stands & remove the wheel arch liners.
These are secured by a cross head screw, 3 torx screws & liner pins each side.
To remove the liner pins you push in the centre with a small screwdriver about 5-6mm & then pull them out using a panel puller.
There's quite a few, but you only need to remove the front half.
Why do you want to replace the original,
If it's not working the chances are it's the horn pad contacts under the airbag on the steering wheel.
Any further information just shout DDD
2006 BMW e61 535d m-sport
run's for cover
