Cruise control will not engage
barbaren
Post by barbaren »
Hi guys
Help me please. I have fitted my 2004 406 hdi with cruise control.
I've done everything as I should. New brakepedal switch. Adjusted them so they work in the correct order. Activated in Pp2000.
I can see everything works. It turns on. All buttons both + - and pause works. But when I try to engage it. It will not hold the speed.
I have noticed that the clutch switch is inactive both with pedal up and pedal down. Could it be because on that? Or is there something I have forgotten?
Re: Cruise control will not engage
Yes, check the clutch switch. Both, brake and clutch, should be working.
barbaren
Post by barbaren »
Got it to work[emoji4]
The clutch switch needed to be activated in BSI.
Good work, well done. 8)
