fuel pump wires
fuel pump wires
Hi can sanybody tell me which wires are which going to the tank fuel pump, paynes manual only shows an earth and live, there are four wires going to mine, also there is a socket with a few wires in it on top of the tank which is not connected to anything, whats it for?. thanks for any help, oh 2.0 110
Re: fuel pump wires
Feed for the additive pump maybe? Sedre's showing it in the same place as the lift pump
Lift pump wiring:
the other 2 wires are the level sensor, obv. Haynes,Schmaynes
Lift pump wiring:
- Attachments
- (50.06 KiB) Downloaded 2 times
Re: fuel pump wires
FWIW (and assuming memory serves), the additive pump lives in the additive tank. The additive 'injector' lurks somewhere near the lift pump/fuel sender unit, but has no wiring.
Re: fuel pump wires
additive wiring makes sense, mine hasn't got a dpf they probably use the same loom and just leave it redundant, thanks for diagram.
Re: fuel pump wires
No worries.
If you're really curious if you can give me some codes off the wires I can probably look them up.
