Starting engine standalone (connecting IMMO to BSI/ECU)
My first post here so hi to everyone! I had '99 406 2.0HDi 110 (half-mux, Siemens BSI3) that was scrapped a year ago. I've removed all good stuff from it including engine with its harness, BSI, ECU, immo coil, key. In Haynes there is how BSI and ECU are connected together, but in VAN section of a wire diagram there is only one power wire from BSI to immobiliser coil (at least only 5 left from 6 to figure out). So I request for BSI connection diagram and/or ECU connection diagram and/or immo connection diagram. If there would be full BSI/ECU/IMMO pinouts diagram that would be nice as well. I'm from Poland, so I have the wheel on the wrong side ;) Thanks in advance!
