hi
my side mirror memory postion does not save the settings, while both controls are working, after setting the both mirrors on desired settings, then i do press M+1 OR M+2 to save it, and it makes a beep sound, so whenever i recal the memory by pressing 1 or 2, the last previous setting will not be recalled, it will give a different memory postion and the two tiny ugly motors keep making sounds then stopped..
but all other functions connected to the memory ECU is working fine including the seats...is only the mirror does not save previous position setttings..
any idea on whats wrong?
side mirror memory
Re: side mirror memory
SOLVED
repaired broken wires from the mirror down to seat ecu
