ABS block
NinoB
2.2 16v
ABS block
Post by NinoB »
Hi
Please what's this permanent fault :safety relay?
I scanned my 406 abs block, and the message appeared..
Please where can i find the safety Relay?
Regards
Re: ABS block
I got nothing, the internet got nothing :? Something inside the abs control unit? Is the abs malfunctioning?
NinoB
2.2 16v
Re: ABS block
Post by NinoB »
Is just that when i scanned i saw it.. So i got nothing from internet also..
Is sad..
Re: ABS block
FWIW I looked too, without success.
I'm thinking if it does have a safety relay, it's likely built into the ABS unit, the engine fusebox or the BSI
Re: ABS block
I'd say ignore it until it manifests itself in a more apparent manner but, you know, brakes :shock:
Does it clear?
NinoB
2.2 16v
Re: ABS block
Post by NinoB »
Yes... Solved.. It was a fuse in fuse box that works with abs.. So i changed the fused and the fault disappeared..
Re: ABS block
Bizarre!
PSA: Permanent fault; Safety relay.
English: ABS has no supply voltage. :roll:
NinoB
2.2 16v
Re: ABS block
Post by NinoB »
There is a fuse under the fuse box that cut.. So i replaced it and it worked.. Hahaha.. I think is for the abs block because there are wires connected to it
Re: ABS block
Well done for solving it. 8)
Misleading messages are all too common, I had one where I lost the lift pump supply on a Xsara HDi 90, the fault message was an egr solenoid fault.
In reality the ecu was missing 1 out of 3 +12V supplies.
