James Help?
robessex
James Help?
Post by robessex »
Did what you said Monday worked atreat car ran all day
Today it will not start I suppose there was nothing wrong with the immob?
Any ideas
PS No spark
Cheers rob
jameslxdt
Post by jameslxdt »
tdc sensor
ill bet my life on it :cheesy:
robessex
Post by robessex »
Is there anyway to test it, where is it and what does it look like!
Much appreciated rob :D
jameslxdt
Post by jameslxdt »
bolted on top of the gearbox, underneath the thermostat hoousing, its black plastic with a 3mm black cable comming off it with one 10mm nut holding it into the gearbox, unplug it, and at the sensor plug end you should have 3 terminals, i think, get a multimeter and measure AC volts while trying to start the engine across the outer pins of the plug, you should get anything between 0.5volts up to 5volts, if you get nothing, use the multimeter to measure the resistance, if you have open circuit then replace the sensor, if not, take the sensor out and have a look in the hole (very hard to see) and turn the engine by hand you should what looks like i giant cog, eventually there will be a gap between the teeth, if this cog is broken anywhere, you have major problems :?
but the favorite is the tdc sensor
robessex
Post by robessex »
What a nightmare to get to :evil:
multimeter on loom terminal 3.20vdc whether immob on or of
1.75 ohms at 20m on the meter not quite open circuit.
Do I change TDC?
Now its raining :cry:
Robessex not having a good day
jameslxdt
Post by jameslxdt »
you need to measure the A/C voltage comming out of the sensor while trying to start
robessex
Post by robessex »
Sorry James I d assumed the power would be coming from the loom not the sensor!
What do they say, assumtions are the mother of all f*** U**.
Still raining will try in the morning
Cheers Robessex
robessex
Post by robessex »
OK got it back in (TDC) and spun engine on 20v no reading. I will have to hope the internal cog is sound because unless I was one inch high and had better eye sight than the average cat there is no way I can see down that frigging hole!
By the by is it possible for the TDC sensor to short and blow because of water ingress?
The reason I ask is because once the air filter housing was removed I noticed water was dripping fron the thermostate bleed nipple. The cap was cracked, I have always had to put a small amount of water in on a regular basis. I had checked rad and hoses and never noticed this cap because it was obscured by air intake pipe. Swapped it for one of my valve caps!
Monday I will buy a new TDC sensor let you know what happens
Robessex
jameslxdt
Post by jameslxdt »
yeah this is what kills the sensor on the 1.8, 2.0 and the turbo, but usually the thermostat housing leaks onto the sensor, if you got no reading it is most likely dead
but are you sure you measured A/C voltage not D/C?
robessex
Post by robessex »
I am such a prat :x DC retryed on AC measures 0.49v Now what?
Robessex
jameslxdt
Post by jameslxdt »
thats border line, you need 0.5v to just about start so its hard to say, can you get hold of another sensor cheaply?
robessex
Post by robessex »
How much is a sensor I was going to buy one on monday. If its not the sensor what else can it be?
Robessex
jameslxdt
Post by jameslxdt »
i think euro car parts do them for about £20 plus vat
robessex
Post by robessex »
James your a star :cheesy: Went into peugeot today and brought new TDC sensor very cheap at £22
inc. vat. :D Fitted this evening and it stated first time!
Much appreciated Robessex
jameslxdt
Post by jameslxdt »
im not just a pretty face lol
:D
