1.9 TD Rev Counter Stuck
About 70% of the time I'm driving, the rev counter needle is not working, stuck at about 1900 RPM. When it does randomly decide to work it seems a bit off. I did a search on the forums, but I couldnt come up with a clear solution. I'm a complete novice as far as mechanics go, so if you know the cause, please be gentle in explanation! Cheers!
Jeff
- jameslxdt
take the tdc sensor out of the top of the gearbox, its black and under the thermostat housing and is held in with one 10mm bolt and give it a good clean with brake cleaner and a rag, and fit it back
