BAttery charge fault
diesel.weasel
Post by diesel.weasel »
When the engine revs on my HDI 90 fall below 2000 rpm I get "Battery charge fault" on the display.
Is this a common fault on these querky french cars?
I think it may be a voltage regulator on the alternator, does this theory hold water?
If it is does that mean a new alternator, or can a new voltage regulator be bought seperately?
Any help appreciated.
Thanks,
DW
jameslxdt
Post by jameslxdt »
get your multimeter and measure the voltage across the battery with engine running, you should have arround 13.5 to 14volts if not replace the altenator
