Another anti-pollution thread
Baz W
Post by Baz W »
Has anyone come across this fault with an ecu fault = fuel pressure regulator?
Comes at random, put the car in limp (wrist) home mode and everythime i get it to a garage its working fine and always comes up with this code. Last time i checked the fuel filter it was full of bit of metal so i assume my fuel pump is eating itself slowly. The revs also fluctuate at idle too.
Does this sound terminal?
Baz
jameslxdt
Post by jameslxdt »
sounds like your low pressure pump has almost failed and filled the high pressure pump regulator with sh*t, or metal particles :cheesy:
eventually the high pressure pump will fail and you will need a complete fuel system, basically, both pumps fuel lines and a filter housing :cry:
Baz W
Post by Baz W »
Sounds pricey.
Its off for a service next week so lets see how much fuel pump is in the filter this time. Idle fluctuates to a the point where it stalls quite often now.
grrrrrrr
Baz
If the LP pump starts to break up I thought the filter will catch everything before it reaches the HP pump?
jameslxdt
Post by jameslxdt »
sounds very much like a blocked regulator :cry:
Baz W
Post by Baz W »
jameslxdt wrote:sounds very much like a blocked regulator :cry:
So where does that live? (i know next to fook all about em)
Baz
quicheb
Limp wristed performance
Post by quicheb »
jameslxdt wrote:sounds like your low pressure pump has almost failed and filled the high pressure pump regulator with sh*t, or metal particles :cheesy:
Had a similar problem in April but as it's the wife's car for ferryig the kids around, I wasn't too bothered! :evil: Until it happended to me and I was limited to 2000 revs. :x All the way home :cry: Pug dealership were useless so took it to a Diesel specialist who diagnosed the cerine fluid for the particulate emission control system was all gone and that the filter was blocked. Total cost to rectify on a 2.2Hdi was £400. :shock:
Quicheb: the closest to a physical manifestation of Peugeot electrics that man can get
