Has anyone changed a lambda probe / mixture sensor / thingy on a 406 V6? My good lady's estate has the engine management light on and a while back I got someone to read the fault code which said the sensor (air mixture, I think) on bank 1 was defective (Tesco'd I think). The car runs fine and seems not to smell but it is due an MOT this week and I have a feeling that the emissions may not conform. Looking down the back of the engine I can see a sensor in the top of the exhaust pipe, it looks like a simple job to replace it but I don't know oif that is "Bank 1".
I'm guessing here but I assume that the Bank mentioned is a 3 pot exhaust manifold, and there is one on each side of the engine? Is there a straightforward test to check if a sensor is dead and can they be resuscitated or purchased easily?
Cheers
Lambda probe?
Lambda probe?
Skinned knuckles and dirty nails
is it the early v6 or the later 2000 on one? bank 1 is the front bank nearest the radiator.
post 2000 v6's (211 bhp) have 4 lambda sensors, 2 pre, 2 post catalyst. im not 100% sure whether the early engines have 4 or not.
the are pretty simple to change. a good 22mm spanner usually undoes them. if they dont budge with a spanner, cut the sensor body off half way down and use a deep 22mm socket on a bar.
1990 205 gti16, xu9j4 power! graphite grey, white speedlines, 306 brakes, ice, half leather.
going to enjoy smashing ctr's
2000 d9 406 executive v6 estate with an auto box, bit of a hot hatch slayer ;) currently munching 'hot' hatches.......
V6 Lambda
Hi, Thanks for the information. I don't know if my wife's car is a late or early one. It is a year 2000 on a W plate with the plain glass face lift headlights. Does this help?mikey s wrote:is it the early v6 or the later 2000 on one? bank 1 is the front bank nearest the radiator.
Do you know how I check to see which is the defective probe? Can I use a meter on them to see if they are open circuit / closed circuit. Or perhaps measure the resistance across the terminals? I'm splashing about in unknown territory here using words and describing techniques that I probably wouldn't know how to apply, but I'm more than keen to have a go. I'm fed up with giving the local Pug dealer enough money to buy a yacht, while I can't afford a Mirror dinghy. I went out and bought a trolley jack and a pair of axle stands, now I want to get stuck in.
if its an 2000 on a w it will be the later v6. you really need to get the fault codes read again to ascetain which of the lambda sensors is at fault. as a rule of thumb, both should be changed at the same time. just dont be tempted for cheap/secondhand sensors. they rarely work and can actually cause even more headaches.
plump for either genuine or ngk sensors.
Thanks for your advice.mikey s wrote:if its an 2000 on a w it will be the later v6. you really need to get the fault codes read again to ascetain which of the lambda sensors is at fault. as a rule of thumb, both should be changed at the same time. just dont be tempted for cheap/secondhand sensors. they rarely work and can actually cause even more headaches.
I will see what happens when I pull the old ones out!
Hi, I bought a sensor from Peugeot and swapped it with one of the front sensors, then the fault code changed from error on bank 1 to error on bank 2. I switched the new sensor with one on bank 2 and no change, so I swapped it with the other one on bank 2 and then the code went back to error on bank one. Hey Ho I thought...two knackered sensors. I bought a second sensor and fitted that to bank one and now all the error codes have gone away. I'm pleased to have solved the problem but am a bit gutted at having to pay £147 + VAT for each sensor (£345.45).Dumbclutz wrote:Thanks for your advice.mikey s wrote:if its an 2000 on a w it will be the later v6. you really need to get the fault codes read again to ascetain which of the lambda sensors is at fault. as a rule of thumb, both should be changed at the same time. just dont be tempted for cheap/secondhand sensors. they rarely work and can actually cause even more headaches.
BUT it passed the MOT !
