406 ABS LIGHT
tonirlane
406 ABS LIGHT
Post by tonirlane »
hI there, 110 406 estate 2000 model. The ABS light keeps comming on intermittantly, sometimes after 1/2 hr driving sometimes after 1/2 minute, some times not for a day or so. Car does 80miles/day. Have checked resistance readings on all 4 sensors and the all read the same. Have disconnected and wd40tid all the connectors, no difference. really annoying when you can't see the clock, temp and which radio stn you have on.
Any body got an idea ?? :evil:
What's it saying on the display?
tonirlane
abs light
Post by tonirlane »
hi, the light says ABS FAULT on the main display, that blocks out everything else.
406silverhdi
Post by 406silverhdi »
clean the sensors and check your disc brakes are not rusting from the inside out
i had this on my 106gti. the discs were rusting from the inside as they were vented, then the metal would stick to the magenetic abs sensor and cause a fault until the bit of metal fell off :)
tonirlane
Post by tonirlane »
406silverhdi wrote:clean the sensors and check your disc brakes are not rusting from the inside out
thanks for that will do and let you know, regards
toni
