"sticky"speedo
"sticky"speedo
Hi Guys
my speedo sticks at 40mph after just pulling away,and stays at 40 unless i give the panel a sharp tap.This fault is intermittant but is getting worse and is happening more often.Any suggestions
thanks
thanks
hi
this is a common problem and one which I need to correct on my pug , there are some threads on here which cover this problem but I will try and help
1) check the back of the instrument panel for cracked or dry soldered joints, good first option if you are confident with a soldering iron.
2)There is a black ecu unit behind the glove box (size of packet of fags) some 406's may not have these so go to your local pug main dealer and they can take your vin number to confirm if your pug was fitted with one.
3)The speedometer transducer unit which is fitted just above the drive shaft on the gear box
hope this helps will be sorting mine out next week and will post my results
- jameslxdt
i have also seen on occasions the black backing with the numbers comes away from the base of the speedo and fouls the needle so the speedo gets stuck
Mine's been very intermitant recently... hardly working ever but once in a while it'll come to life for a quick dance and die again.
I changed a few of the dash bulbs last night and think I must have disturbed the problem area as it was working ALL the way to work this morning... interesting... im going for a dodgy connector wiring.
- michaeljclark
"sticky"speedo update
apparently Eurocarparts do a modulator box (fag packet size) part no 1929s that cures the problem,costs about £40.this fits under the glove box.
Re: "sticky"speedo update
I had a look on their site to see if they sold them but couldnt see anything - that part number doesnt look like an ECP part number either.andy heeks wrote:apparently Eurocarparts do a modulator box (fag packet size) part no 1929s that cures the problem,costs about £40.this fits under the glove box.
Hang fire, i'll give the local branch a call.
- michaeljclark
Pug trialed mine by substitution. It was duff of course. I'm thinking that a big part of maintaining these ever-so-bleedin'-complex cars is knowing when to stop guessing and call in the experts. This doesn't necessarily mean Pug, that's like going to your GP for heart surgery.
