bsi fault???
rigsby29
bsi fault???
Post by rigsby29 »
ive had a look at the 406 hdi 1999 ive just bought & found a few faults
1. the ignition lights stay on with the key removed
2. if you disconnect the battery them reconnect it the mileage briefly reads 923700.00 then goes to 0000 with a spanner next to it & 000000 underneath it
3. it turns over but will not start
4. you can turn the heater on with the key out
5. the rdio will not turn on with or without the key
