D9 window switches
D9 window switches
I have fitted some D9 door cards in my D8 but the wiring connectors are different,can anyone scan wiring diagram for D9 switches so i can fettle them in. Thats both front doors-many thanks in advance
Re: D9 window switches
I now have the connector for the passenger front door,5 wires are the same colour as the original connector but there is a small green/yellow wire extra on the D9 connector.
anyone got any idea where this connects to?
Earth, according to Haynes, so it's probably anything but the oeuf...
The D8 diagram doesn't actually feature any colours, which is probably why you didn't get much response before. Probably best to meter/test lamp it to be sure.
Thanks for that-i thought it was an earth but french electrics are a nightmare.
Son who is an auto electrician wont touch my pugs as he says they are a disaster looking for somewhere to happen.
- Captain Jack
How did you manage to fit the D9 cards to the front? I know they "fit" but there's nothing to securely hold it in place. Did you create your own bracket thingy?
Back ones obviously fit as standard with a slight modification to the door handles.
As for the switches, I am going to make a converter so that I don't cut any wires. Will probably use a multimeter to work it all out.
But that's a job for a warmer weather!
Keep up the good work cpt jack and eventually you will end up with a
D9
D9
- Captain Jack
...with reliability of a D8
Simply Captain-down the scrappy with the cordless drill & get the brackets off a D9-scrappy is full of D9's but not many D8's about,more reliable i suppose
Re -the rear door handles,ones on the D9 cards were rough so i swapped them for the D8 handles (no switches either)
As for fettling the different connectors-few cans of lager to the son & heir to fit small lugs onto D9 tails & plug into D8 connector
simple innit
simple innit
think you got that slightly wrong old codgerold codger wrote:Simply Captain-down the scrappy with the cordless drill & get the brackets off a D9-scrappy is full of D9's but not many D8's about,more reliable i suppose
being able to afford to upgrade to sheer style and performance of a D'9 hence the constant fettling,
and there maybe 1 or 2 D9's in the scrappy but this is usually due to accident damage usually inflicted
at the high speeds these much adored cars are capable of
Most of them rear ended,could have been sudden breakdown?
- Captain Jack
old codger wrote:Most of them rear ended,could have been sudden breakdown?
It is more likely that the driver behind was transfixed by the beauty of the D9.old codger wrote:Most of them rear ended,could have been sudden breakdown?
406 Coupe S HDi
PP2000 clone interface
406 Coupe S HDi
V6 i love you !!!! ..... er in a manly car adoring way of course
