Hi, this is my 1st post on here, hello to you all.
I have a 's' reg 406 2.1 td glx saloon.
the digital climate control has stopped working, nothing is lighting up and i have no fan, heater etc.
i have changed the complete box with a tested working one and still nothong. All the fuses have been checked and appear ok.
Is there something else someone can think of before a visit to a main dealer and lots of £££££ spent just before xmas.
if i put the cars lights on, it iluminates then as it should so i know power is getting there but the display stays off with all other controls.
Many thanks
Paul
CLIMATE CONTROL IN-OP PLEASE HELP
Re: CLIMATE CONTROL IN-OP PLEASE HELP
Illumination probably just means the positive feed for the lights is getting there. When you say you changed the box, which box do you mean? It sounds like there's no power getting to it if nothing works at all. I'm not sure of anything specific you should be looking for but if you meter test the connectors for power.
Hunch: Ignition switch.
Thanks for your reply, by box i mean the whole control unit just above the stereo, i went to a local pug breaker and we swapped then over but still nothing.
- puggy
- Resident Pervert
As steve says try the ignition switch,had a similar problem with mine.
take the column shroud off and wiggle the wires at back of switch you
might hear the fan kick in..
Thanks for that guys, will try that and let you know how it get on.
many thanks
many thanks
