putting fog lights in an LX
as per the title a bought a set a fogs and the indicator stalk with front fog switch on it. are they just a straight fit in as i see some connections on the bumper that i asume would be for fogs if she ad em fitted
Re: putting fog lights in an LX
Yep-leccy plugs are there-stalk goes straight on-if you look under the fuse box under the drivers footwell right at the back on the left hand side is an oblong black relay-fog one is the same & fits immediatly to its right-scrappy is the best place to get one.
i used a crochet hook to pull the springs back to fit on the lamp-bluetack to hold bracket while i fitted the torx screws
mighty m8 thanx
forgot-used bluetack to hold bracket end of spring too.
got them in, good job
