Immobilliser Query
nxtlevel2000
Immobilliser Query
Post by nxtlevel2000 »
wheni put the key in the ignition, then light is red, after entering the code the green light comes on. So both lights are on. nothing happens, i can enter any 4 digit numbers and same thing will happen. can someone please help me, i have lost my manual. i NEED URGENT HELP. thanks.
Re: Immobilliser Query
try disconnecting the battery for a few minutes?
nxtlevel2000
i tried it but still didnt work. any ideas will be greatly appreciated.
nxtlevel2000
Silly question, has the code been working and just suddenly started failing?
You only get both lights if you enter the wrong code. Disconnecting the battery will reset the system; I discovered this myself when I forgot the code on my old LX :oops:
nxtlevel2000
teamster1975 wrote:Silly question, has the code been working and just suddenly started failing?
i disconnect the battery for about 2 hours, still did the same thing, i got the same result by entering any 4 digits. i am really stuck,please help.thanks.
V6Exec
Post by V6Exec »
If you have lost the code, a replacement ECU may be required. The whole point of the keypad is to stop TWOCing.
Good luck
406 Coupe S HDi
PP2000 clone interface
nxtlevel2000 wrote:i disconnect the battery for about 2 hours, still did the same thing, i got the same result by entering any 4 digits.
So you're definitely putting the correct code in which has worked in the past?
Also, has the keypad been changed? This is coded to the ECU.
nxtlevel2000
yeah, the code worked before this problem occured. so i really dont know, oh yeah where would the ecu be????
nxtlevel2000 wrote:oh yeah where would the ecu be????
Open the bonnet and it's under the black plastic cover to your left next to the washer fluid and coolant reservoirs
V6Exec
Post by V6Exec »
Some links that may help:
First,second
And if all else fails you could try this or this
Good luck getting it sorted.
406 Coupe S HDi
V6Exec wrote:Some links that may help:
Interesting. I wonder how they get the codes out :?
V6Exec
Post by V6Exec »
Eprom reader. There was a thread on another forum dealing with lesser pugs and shitrons that talked about doing a dump of the eprom and burning the content to change keypads.
Couple of links here and here
406 Coupe S HDi
Thanks for that,I'll have a read!
Not that I hope to put such a thing into practice! :lol:
