faults from nowhere help??
- 1.6 8v
Hi all i am new to the forum, i have a 2003 2.0hdi 90bhp, with bosche fuel rail, 70.000 miles
I only use it once a week and it has always been fine, however today i went out to use it and it would not start it told me i had a airbag fault, the the key sign came on and it told me i had an immobilser fault, now it just shows econemy mode on the display for about 10 secs and then it goes black and the car wont start, it just keeps turning over, any thoughts would be appreciated.
Paul
Paul
- mjb
- Site Admin
Re: faults from nowhere help??
My money's on a dead battery.taylorp wrote:I only use it once a week ..... econemy mode
Mine toomjb wrote:My money's on a dead battery.taylorp wrote:I only use it once a week ..... econemy mode
406 Coupe S HDi
PP2000 clone interface
406 Coupe S HDi
Duff battery or dodgy connection. What's the voltage on the battery?
CAUTION: DON'T GO ANYWHERE NEAR IT WITH JUMP LEADS!
- 1.6 8v
Thanks for the replys, why should you not go near with jump leads, and would a low battery stop me from starting meaning voltage rather than amperage, surley if there is enough to crank it over it should start or does it rely on sensors etc giving the coerrect voltage before delivering the fuel??
Paul
Paul
- jameslxdt
D9 electrics are very weak and jump starting can do some nasty damage
never ever had a d9 electrics fail due jump starting before. had probably 10 as sales cars so we have jump started almost all of them with no probs before.jameslxdt wrote:D9 electrics are very weak and jump starting can do some nasty damage
1990 205 gti16, xu9j4 power! graphite grey, white speedlines, 306 brakes, ice, half leather.
going to enjoy smashing ctr's
2000 d9 406 executive v6 estate with an auto box, bit of a hot hatch slayer ;) currently munching 'hot' hatches.......
- jameslxdt
even so i dont ever jump start a car, there is no safe way to do it and there will always be a risk of electrical surge, so its a safer option to charge the battery
- 1.6 8v
Thanks i have bit the bullet and purchased a new battery this morning however i still have the same fault that the airbag light is on and it wont fire, is there a safety feature built in to stop it starting if there is an airbag fault occurs?? im clutching at straws i know but it was fine one day then the next it just was not.
Thanks Paul
Thanks Paul
- jameslxdt
car will start regardless if there is a fault in the airbag circuit, i know its a long shot, but as you look at your engine with th bonnet up, in the upper far right hand corner there is a fuel shut off valve, its the red thing in this pic
if you press it and here a click its reset and may start, as the airbag light has come on it may have had a bump which triggerd it
- 1.6 8v
thanks for that but i cant find the reset switch??
The red cap is the reset
Press it down - see if it clicks/helps
406 Coupe S HDi
406 Coupe S HDi
- jameslxdt
some times they are black too, just push the centre of it
- 1.6 8v
Thanks but there is no switch around there i have included these pictures hope they cast more light on it.
- jameslxdt
thats weird, you said its a 90, thats a 110
