dignostic socket faults
Hi, the diagnostic socket does not work on 1 of my D9's.I've used the code reader on the other 2 with no probs.
I had not used the socket on this car before, but when it deleloped several strange faults I tried to read the memory but the code reader doesn't even light up?
First I noticed the rain sensing wiper stopped working, although the actual wipers worked OK.
Then I noticed the electric seat adjustment would only work after the car had gone to sleep & stopped working again after I started driving again.
Then I noticed the door mirrors had decided to follow the seats.
Next the air con had gone out in sympathy, along with the dimming mirror.
Not being able to access the OBD I started trawling the fuse board & found No 22 was blown. replaced the fuse & bingo, everything back to normal EXCEPT the diagnostic socket which probably didn't work before anyway.
So any Ideas why the dignostic socket might not work?
- DaiRees
- Site Admin
Re: dignostic socket faults
What engine and year is it? Neildavies' 2.2 HDi coupe doesn't work with our diagnostics.....
It's a year 2000 2.0 HDI Exec Estate, same year as 1 of the others which does work.
- DaiRees
- Site Admin
Is the other one a HDi too?
I think..... Diesels didn't have to be OBDII compliant until 2004.
I haven't got time to look at the moment, but this may help. http://en.wikipedia.org/wiki/OBDII
Yes 1 of the other cars is identical except the colour. The fact that it has the socket surely means I should get something?
- DaiRees
- Site Admin
Not necessarily, Neil's has the right socket but it refuses to talk to either the handheld or PC based diagnostics. Maybe you're 2 are just either side of the switchover?
I'm gonna have to declare a "dunno" on this one, someone else will tell you soon I'm sure
- jameslxdt
the code reader should light up even if its not compatable, i suspect a knackerd BSi if theres no communication
Haynes says there's two fuses, one direct and one ignition, any help?
Ok, do you know the fuse numbers?
If the BSI is knacked how come everything works OK except the diagnostic plug? Shouldn't it at least light up the tool.
Haynes says F14 & F32 in the engine fusebox, so check these ones... last.
