While installing my retro-fit front fogs ('96 1.9 TD LX D8 saloon) I noticed that the rear foglight switch no longer lights up when depressed and the rear foglight also doesn't come on.
I have so far installed the front fogs and the extra black relay under the dash that runs them. I have yet to install a front foglight switch (BTW it is a switch, not a stalk - this is confirmed by the handbook and a connector behind the blank where it goes - possibly this is because this was one of the first D8s?).
I have checked the rear bulb, switch, switch connections and fuse (number 18) and all seems good. I have also tried removing the front fog relay to see if my in-progress retro-fit was causing a problem. No joy with any of that.
Are there any other relays, or areas that I can check, because I can't think of anything else that could cause this except a problem with the loom somewhere
