BSI PROBLEM HOW MUCH
elaine
Post by elaine »
i have a 406 hdi 90 hp was checking all my fuses and left the keys in the ignition , immobiliser fault came on then it went into economy mode and wouldnt start, got an auto electrition to check it out ,he said everything was ok so it must be my bsi unit and would have to take it to a dealer any idea how much this will cost,do you think my key would just need recoded, have been off the road for 2 weeks know:) :-) :oops:
djp30djp
2.2 16v
Re: BSI PROBLEM HOW MUCH
Post by djp30djp »
Try this .
[quote]Before sending the unit try the BSI Reset procedure as this may cure your faults:
Put the driver's window down, lift the bonnet and ensure all equipment is switched off.
Ensure all doors are closed and remove key from the ignition.
Wait for 3 minutes, disconnect the vehicle battery and wait 15 seconds.
Reconnect the vehicle battery, wait a further 10 seconds (do not open doors.).
Switch on the side lights through the driver's window.
Switch on the ignition and check system's functionality.
Hold lock button on key down for 10 seconds.
Remove key open & close door test central locking system.
Start the engine and complete the system's check.
Failure to follow this procedure could result in incorrect operation of many BSI related items.[quote]
Or leave the battery disconnected for say, 24 hours. Might be useful to slap it on charge too. From what I've read on here BSI failures are usually a bit more, erm, dramatic.
elaine
Post by elaine »
steve_earwig wrote:Or leave the battery disconnected for say, 24 hours. Might be useful to slap it on charge too. From what I've read on here BSI failures are usually a bit more, erm, dramatic.
hi steve tried leaving my battery off for 24 hrs still came up ecomomy mode thanks anyway :) :cheesy:
elaine
Post by elaine »
thanks puggy was on their web site going to phone them tommorrow. :) :)
elaine
Post by elaine »
djp30djp wrote:Try this .
thanks going out to try this now hope it works :) :)
elaine
Post by elaine »
[quote=thethe"djp30djp"]Try this .
Failure to follow this procedure could result in incorrect operation of many BSI related items.[quote]had to get the bsi re-programmed so the car is now working fine thanks!!!!!!!
elaine
Post by elaine »
had to get the bsi reprogrammed its now working ok thanks!!!
elaine
Post by elaine »
thanks!! had to get bsi reprogrammed
