Hi
As I drive along in fifth gear at 70 on the m-way, suddenly the speedometer drops out and goes to zero, and I have no idea what speed I am then doing. This will last for about two mins, then it will all kick back in again and the speedo will then "pick up" and revert back to the speed currently being driven at the time.
Any quick fix or ideas?
Speedo electrical fault
- Site Admin & Mad Biker!
Re: Speedo electrical fault
No worries, everyone's pretty easy going here!
Mine used to do the same.
It was dry solders on the posts that go from the board to the actual instrument in question, the fuel guage did it too.
Re-solder the four posts on the duff dial and it should fix it.
Nick put a good image of the specific parts in the gallery.
Cheers
Steve
Cheers
Steve
She cannae take it captain!
Proud owner of the Funbus 98 2.1td estate being reborn £70 at a time.
Still need new back-plates.
- neildavies
It was a £40 black box behind the glove box for me. Over time the problem got worse until it didn't read the speed at all. Mine was a 198 2.1TD and you got at the box from underneath the glovebox in the passenger footwell.
2007 307cc Sport 2.0 HDi 136
A quick way to check which part is duff is to give the speedo a thump or push the bottom of the thing when it's not displaying properly.
If it jumps to life then it's more than likely the posts, if it doesn't then good luck looking.
Hope this helps
Steve
Hope this helps
Steve
