Right, first of all I would like to give a big shout out to the peugeot electrical engineers and the budgeting department, without you I would be a happy bunny. If a car cost over £20k ten years ago, you would of thought they would put some quality connectors in.... but I guess not as I've already had to solder the main fan power as the connector burnt out and now this.
Anyways, I tagged on to a post that my outside temp sensor had gone, and that was that. On the multi-funtion display thingy, the temp now just has two flashing bars after driving and the temp just going up two degrees every 3-5seconds untill it hit 70. When I first brought the car it only had one flashing bar and the climate control seemed to do it's job correctly. For some strange reason, one day I turned the car on and it worked, showed the right temp (+/- 1deg), and it stayed like that for a year.
From what I can gather, the one flashing bar is the sensor is registring under it's range as the thermistor has gone (circuit open). The two bars is that it's registering over it's range (70+deg) because the thermistor has gone, but is shorting the circuit., or visa-versa, (This is what I understand from the electronics course I did) because the sensor is just a thermal resistor.
The trouble has now wormed it's way to the auto climate system
This morning in the frost, the fans had no idea what they were doing! Almost full one min, off the next, the on and off all the way to work. I just put it on manual in the end. My instinct is telling me that the car thinks it's hot outside, so pulls some air in, realises it's now cold, turns the fans off, then it registers it's warming up in the cab and puts the fans back on to draw more air in... and so on and so forth.
Is this right, does the outside temp sensor have any control over the auto climate control at all or is this just wishful thinking and my Birton control box has gone senile? I e-mailed my local stealers and the external thermistor is about £15 and from what I have read on here goes in the passenger side wingmirror. If it's the Birton box, how much and where could I source one of those from... also fitting, easy or do I have to take the engine out to get to it?
Any input on this issue would be great, thanks guys.
