I got one of those OBD cables from ebay and have spent most of the day pulling my hair out. The cable works because if I use scan tools then I can get in and see the RPM............ but thats about it!
So I need some different software one that looks good is called PSADiag but god knows how much it is, has anyone been sucessful with the cheap/free OBD software in clearing down DTC? mines a 2001 petrol model.
Carpman
Software for OBD
Re: Software for OBD
Cheers m8, I checked it out but it is a dead end which is a shame.
Carpman
Carpman
OK, try this. http://www.geocities.com/a_ser_files/
Thanks for the link, but that software is for a pocket PC, I did try the alternative scantools software for the ELM23 cable earlier, but it didn't work, it does connect but only talks to the rev counter.
Carpman
Carpman
- DaiRees
- Site Admin
I think it's scantool that I use, Seems to work OK, gives readings for quite a lot of the parameters. Haven't had any fault codes since I've had the reader though, so can't coment on the reset.
Whilst on the conversation of ODB. Does anyone know of a cable that works with a D8 2.1 TD LX?
Cheers
Cheers
The cables are on ebay but the problem comes when trying to find a decent bit of software to work with them, all the software tools are for cars that are OBD2 complient which are supposed to be petrol cars 2001 on, and diesel cars 2004 on.
Mines a 2001 petrol but it still doesn't work f'ing Peugeot
Carpman
Carpman
How about this? http://www.scantool.net/?mode=browseSoftware
or this? http://www.digimoto.com/installs/lite/d ... efw106.exe
or this? http://www.werner-digital.com/obd/software.html
