Airbag Warning light
markh
Post by markh »
Read all the threads on here now refering to Airbag failures and it seems apparent that the Airbag warning light flashes to determine the actual fault. 1.. Permanantly on
2.. On for 5 seconds then flashes
3.. flashes
Can anyone tell me the actual fault allocated to each warning description
Re: Airbag Warning light
I dunno about any of the others but on my D8 the constant flashing was the airbag ecu.
(Well, either that or it was something much simpler but Pug charged me for changing the ecu...)
On mine it flashes when the under seat connections are playing up and it's permanently on if you disable it via the key near the handbrake (I tried that once).
markh
Post by markh »
Cheers for the reply,
I'm left with three options, ignore it (as it's not an MOT fail) cut and solder seat airbag/pretensioner harness (which you have to cut and solder again if you have to take the seat out for anything) or replace the comm2000, which, is looking favourite as the indicator stalk is faulty.
markh
Post by markh »
Air bag light still on, indicator stalk an absolute nightmare and now the horn doesn't work, can't see how it can be anything other than the comms 2000
Steady on supa! :shock: :lol:
steveleyland
Post by steveleyland »
Picked my 406 estate up today and first off the sat nav stopped working now airbag defective light coming on any ideas and what is comm 2000 ?
cheers
Steve
Airbag light is probably connectors under the seats, and sat nav unit needs a clean (I answered that in the other thread).
Loads of info on here mate, try a search on both topics. :wink:
steveleyland
Dai Rees,
cheers mate checked under seats and connections must have been problem in past they have some electrical tape on them just gave them a bit of a squeeze and airbag light gone off. No joy with satnav have cleaned disc and unit
steveyleyland wrote:any ideas and what is comm 2000 ?
Comm2000 info
