The trip computer has never worked since I got the car, although you cant expect too much from a car that only cost £150. Its done just over 200K and I have done a lot of work on it to date. As it is well economical on diesel if your careful, and quick as well (if you need a turn of speed, though obvoiusly not as economical as when its been driven carefully), so to my mind its worth trying to get it back into reasonable shape if possible.
Its been fed with copius quantities of new parts mainly from GSF etc and good s/h bits from the scrapyard as required. So far I have changed the timing belt (plus water pump, tensioners, and oil seals), replaced various suspension parts, renewed most of the rear brake components, fitted a s/h windscreen, fitted new lower engine mount, and fitted many s/h bits mainly missing trim items etc.
This trip computer gismo was the next item on the to do list, and I feel that a couple of stalks from the scrapyard would be worth a gamble. I would hate admitting defeat and having to go to the main stealer just to be told I need a new BSI unit for say £500 + VAT
From reading other threads on this forum, if it did prove to be the mythical BSI unit. Hypothetically speaking could I not get a s/h BSI from a scrapyard, send it to an independant remanufacturer ( they then do their thing ), and then I fit this item to my car, problem solved?
