Hi guys i have a x reg 2000 90bhp rapier d9
My aircon is no longer blowing cold air, the internal blowers work but not pumping out hte nice cold air like normal
When i press the aircon button i can hear the usual click, the front rad fan runs, but no air
the pipes that usually get covered in condensation are not getting covered
Any clues
Its been in my family for 5 years and never regassed could it be that or some electrical problem
Thanks in advance
aircon fault
Re: aircon fault
It's probably low on gas.
My condenser has just blown for the second time (see my thread today) but my compressor still runs! I wouldn't run the a/c now cos you'll stress the compressor and they aren't cheap.
Once theses systems start leaking it can all be over in a few days.
You could just have a quick look at the pollen filter to check it as it might be blocking the airflow (there's a foam piece that can drop down onto it) but I doubt it really.
Start looking for signs of the dreaded green gunge
Re: aircon fault
Hi from SA.
I have a problem on my 406 as well.
It has lots of gas and comp. is kicking in but no cold air and at pipes no condensation , it seems some one has tried to repair the wiring at fan and by pass switch with new after market switch but all has power even old switch. Any segestions or wiring daigram.
406 2.0lt 16v STI owner and proud of it.
Re: aircon fault
Oops sorry I forget to mention that if you get hot air , a suspect can be the recuirculating air buton check if the flap opens at the dust filter too, my unit's gears has stripped.
