dodgy electrics / sensors
anyone got ideas on this
1) temp on dash went from +14 to -9 abd ice warning came on
2) mpg showing 205mpg
possibly sensor in mirror may have caused one but dont think that would have any effect on trip meter, took unit out and connection looks ok as far as i can tell
is it likely to be faulty unit or multiple sensors ?
Steve
Steve
Re: dodgy electrics / sensors
Eek! Me no likey
I have a feeling that's just a display and it's controlled by the box of doom. Try disconnecting the battery for an hour?
i could just use own sense i know if its cold and likely to be icy and there is no way getting more than 50mpg unless i walk so could just use screen for radio as sat nav not working anyway
steve
steve
Re: Welcome to www.item4u.com
Welcome to crap4u.com. Cheap garbage of the game.
Knob CD Key $46.90
Knob Online CD Key $46.90
World of Knobcraft CD Key EU $14.40
WoK CD Key US $18.25
Age of the Train CD Key $28.50
10 Million smeg stains $7.97
20 Million jism gold $15.94
5 Age of Smeg Stains $3.00
30 AoS Gold $17.64
Knob Leveling us Level 1 - 10 Package $14.95
Knob Online Power Leveling us Level 1 - 20 Package $49.95
War Leveling us Level 1 - 40 Package $229.95
Knob CD Key $46.90
30 AoS Gold $17.64
- Site Admin & Mad Biker!
now cruise control seems to be playing up not sure if all electrics / sensor problems are connected. Will have to try the BSI reset procedure but thinking that will cause me more problems than got already
Oh crap
Good luck!
think i will need it have you seen the instructions for it, just missed out 1) roll up one of pants legs to start ...
must have been a french mason came up with this routine
I certainly have - what the f...? I must admit, it looks like total bollocks to me & I wouldn't like to try it. What's your cruise actually doing? Maybe it's a coincidence because they don't seem the most reliable of things. Did you try just disconnecting the battery?
yes tried disconnecting battery, got back in car outside temp +10 thought it was sorted started car up went to -11....
bugger..... went for a drive cruise still not working either.
Got a kit that is supposed to give you diagnostics data - website said all diesels from 2004 compatible with OBD2 however peugeot was compatible from 2000 with the HDI . bollocks doesnt fit / work either.
not my type of car had nearly two weeks not stopped f*cking around with it yet
anyone know how much sensor for mirror is or is it cheaper to get whole unit from scrapper ? also seen some electric heated mirrors on tebay for pug guess its not an easy fix to put them on - anyone done it and got them working
cheers
Steve
cheers
Steve
snooze control started working again today
and sprayed some wd40 behind mirror not sure if it "fixed" but went from -10 to +12 which felt about right
- superdooper
The temp sensor is about £12 from a Pug Stealer.
