hi dash on my 406 1.9 td has stoped working only got temp gauge.
got no rev counter/speedo/fuel gauge/mile ometer they all stoped at once any help would be nice thanks
dash not working
Re: dash not working
Hi there, did the connector fall out the back?
hi thanks checked that and changed dash as well still not working thanks keith
Sorry, that was a bit obvious but you'd be surprised... Umm, I take it all the panel lamps are going. Looking at the (probably largly inacurrate) diagram in Haynes, the temperature gauge is the only gauge on there that's not run by a lump of electronics and is fed off the same supply as the warning lighs - the electronic part has its own supply off of fuse 25 (knowing Haynes it's any fuse other than 25
). Time to take a squint at your fuse panel.
hi thanks i have all warning lights and temp gauge i have checked the fuses and tested for power still nothing thanks keith
Bugger
How many power feeds did you find? I think you're looking for a supply issue here, ground would seem to be ok.
- mjb
- Site Admin
I'm going to suggest if both the dash plugs are connected ok, it's one of the harness connectors that has become disconnected. Take the drivers footwell fascia off and you should see a pile of connectors near the steering column. Check one hasn't come loose, otherwise I think the other likely place is beneath the battery tray
