Hello there, Nice forum - just joined!!
My question is how to reset my ecu on a 1996 'n' reg 406 1.9 td? I have fitted a 'Hydrogen booster' and I want the ecu to relearn the new driving style while being assisted by hydro gas.
The 1.9 doesn't have much in the way of an ECU anyway since the injector timing is mechanically set at the injector pump. You stamp on the gas and it squirts more diesel in (timed in sync with the cam) only the 2.1 had a programmable ecu.
What's a "hydrogen booster" anyway ??
Oh, if you want, have a sniff around the 306 DTurbo forums as they "tweek" the 1.9 fuel pump manually for more peformance an a trial and error basis
Edit: I've just You Toobed "Hydrogen Booster" good luck fella
Hi Guys, Thanks for the advice. Am I correct in believing my car has no lambda, no oxygen sensor infact no real engine management at all? I like things simple!! I will keep you all posted on the hydrogen booster, but I have had loads of problems with it. Been trying to set it up properly for months now. I will get there!
