the engine management light keeps coming on and it hesitates a ;ittle so my mate has pluged in the diagnostic and has come up with these codes
p1404
p1403
what can be the cause and how to sort it would be helpfull please
1999 406 hdi fault codes what do these mean
Re: 1999 406 hdi fault codes what do these mean
The p1403 code refers to the EGR valve.
The p1404 code relates to additional heating circuit 2 and pre heaters (glow plugs).
with these fault codes what can i do to fix them ive noticed if i let the car warm up the engine man light does not come on
Be careful with the fault codes, they can just be "clues" at first.
This tread explains what happened when I had these codes........http://407oc.co.uk/viewtopic.php?f=1&t= ... 83899751a6
- Site Admin & Mad Biker!
Crikey, that was a bit of a fault finding mission Welly!Welton wrote:Be careful with the fault codes, they can just be "clues" at first.
Yes Teamy, the ECU sort of 'hints' at what may be wrong, but it won't tell you what's actually wrong - bit like a Woman really
Oh how right you areWelton wrote:it won't tell you what's actually wrong - bit like a Woman really
oh right i was thinking it could be the watr temp sensor so this fault could be to do with the fans and fuses i have got a new glow plug relay but aint put it on yet.
