Mine's just died on the way home
Working fine on the A14, switched back on after the roundabouts and nothing.
Tried fiddling with brake & clutch pedals, selector switch on & off etc, tried 4th too, nothing.
Any ideas people
mjb wrote:First thing to check is the switches on the brake and clutch pedals. Careful not to mess up the brake light switch like I did
Check the fuse too
Had a look at BoL - looks like the same fuse for stop lights & c.c. & it appears to have two switches on the brake pedal Can't be sure cos mine hasn't got all the petrol c.c. gubbins......
dogslife wrote:Had a look at BoL - looks like the same fuse for stop lights & c.c. & it appears to have two switches on the brake pedal Can't be sure cos mine hasn't got all the petrol c.c. gubbins......
One of the brake pedal switches is for the cc, the other is for the brake lights
Sorted!
Just decided to work today, though I'm now thinking a bit of dust in the stalk, as it failed to respond to the increase/set button at least once.....
Looks like the approved technique for 406 electronic gremlins should be 'leave it in the garage overnight'
(Cured the Anti-Pollution Fault too).
I must say, I don't particularly like the cruise control on the '6. When maintaining speed, it *seems* to be quickly alterternating between full throttle and no throttle. My crappy Honda used to do it in quite a smooth fashion...
Captain Jack wrote:I must say, I don't particularly like the cruise control on the '6. When maintaining speed, it *seems* to be quickly alterternating between full throttle and no throttle. My crappy Honda used to do it in quite a smooth fashion...
Could be just perception, though...
My ES9J4 saloon was very smooth working the pedal... when the cruise worked...
The coupe, forget it. It's on the todo list to fix
