wiring for heated seats
now the weather has picked up i am going to wire up the heated seats has anyone done this before i have got the switches but no wires at all so does anyone know a good point to to get a live and earth to them (dont want to use the fag lighter as these already power the movement of the seats) any help at all would be greatfully recived as before i will take pics and do a how too once i have got it all up and running thanks again
Re: wiring for heated seats
Page 3 on this thread: viewtopic.php?f=3&t=3902madbaggie28 wrote:now the weather has picked up i am going to wire up the heated seats has anyone done this before i have got the switches but no wires at all so does anyone know a good point to to get a live and earth to them (dont want to use the fag lighter as these already power the movement of the seats) any help at all would be greatfully recived as before i will take pics and do a how too once i have got it all up and running thanks again
have some of what you're looking for ?
that helps me a little but have already got the heated pads fitted from the oem i got the switches from another car and cant work out how to get a supply to them i will take a pic of my switches and post on because they have got some wire on them but am unsure as to what wire does what
i have had another look at the switches and in the handbook it says fuse 28 is 15amp for the heated seats so i checked the fuse box and the fuse is there so i am nowthinkin that the wiring is already there does anyone know if that is the case (i know they were there on the d8 but not sure on a multiplex d9) any help greatfully recived
Wiring's in place on my D9, just no pads.madbaggie28 wrote:i have had another look at the switches and in the handbook it says fuse 28 is 15amp for the heated seats so i checked the fuse box and the fuse is there so i am nowthinkin that the wiring is already there does anyone know if that is the case (i know they were there on the d8 but not sure on a multiplex d9) any help greatfully recived
viewtopic.php?f=3&t=6421&p=64133&hilit= ... ing#p64133
Seems to indicate that's the way they did it, so you might just be able to plug the switches into the centre-console
end and see how it goes....
