Dim lights on clock/air con displays
leylandii
Post by leylandii »
How do I change the light bulbs for.
a: clock
b: outside temp ( radio channel is illuminated correctly but temp is low)
c: all bulbs for air con display
any help would be greatly appreciated!!
Re: Dim lights on clock/air con displays
leylandii wrote:a: clock
Lever it out
D8: Lever it out
D9: Pry off the panels either side of the display, undo the 4 torx screws, then pull the unit out
D8s Lever out the small panels at the end of the row of buttons+display, undo the 4 torx screws, remove the whole row of buttons+screen
D9s Remove the display
then remove the stereo (including fascia if an aftermarket stereo's been fitted)
then pull the a/c display out
