front fog lights...... they don´t work (v6 D9 estate)
yakker
Post by yakker »
I´ve checked all the fuses put in new bulbs. but still doesnt work. The rear fog lights come on and illuminate in the dash that theyre on. But nada on the front and it doesnt illuminate in the dash aswell!???
Have any of you ever had this problem.
On top of this I also have a problem with my speedo. Sometimes it work some times it doesnt. But when I log from the OBD channel when the speedo doesnt work, then i can read the speed, so its not the sensor in the gearbox??????
Owner of 5 peugeots
106 ph1 rallye w/1,6 litre 8 valve and 126 bhp
205 2,4 litre 16v with 45mm jenvey tb
406 estate 3,0 v6 (d9)
205 1.9 CTI
505 Turbo injection
swiss
Re: front fog lights...... they don´t work (v6 D9 estate)
Post by swiss »
Try removing the indicator stalk and giving the contacts a good clean, making sure it's reinserted firmly
The man with no car
Assuming the v6 is the same, front fogs are worked through a relay in the engine fusebox. A previous owner may simply have removed it so as to be able to use the rear fog without the front, (as you should be able to, if it was designed properly :evil: ) Fuses are F30, (n/s + warning light) & F31, (o/s). Missing / faulty relay or both fuses out would give behaviour you describe.
swiss
Post by swiss »
In which case, get thee to the scrappy for a new relay :)
The man with no car
yakker
Post by yakker »
but the fuses are all there and all the relays as well?!!!!!!!!!!
AAAAAAARRRRRRRRGGGGGGGGGHHHHHHHHH french cars
Owner of 5 peugeots
205 1.9 CTI
505 Turbo injection
Next step is to find out if the relay clicks when you turn the fogs on....
If you can, try a known good relay, (must be the same as one of the others).
