O.B.D. / Diagnostic socket
coco
Post by coco »
Anyone know where the O.B.D. socket is on a 2000 coop?
I think it should be compliant but can't see it in plain view. So, before I start pulling all sorts of things out/off any hints gratefully received
Col
2000 406 Coupe 2.0
2004 Berlingo 2.0HDi
sna400
Re: O.B.D. / Diagnostic socket
Post by sna400 »
if the coupe is like the saloon it should be next to the fuse box down by the drivers leg, but it will almost not be compatable with the EOBD readers you get on ebay and the like, as the standard started 2002
hope this helps!
Simon :cheesy:
D8 2.0 16v LX 406 Saloon
jasper5
Post by jasper5 »
The standard was made mandatory in Europe from May 2001.
CAN Bus is the latest protocol,
sna400
Post by sna400 »
I stand corrected on the date - but i'm still sure that the interface will not be readable due to the date of the vehicle.
jasper5
Post by jasper5 »
Yeah, you are correct, there was a question on this only the other day.
coco
Post by coco »
Thanks, the one I use in my Berlingo is a Scangauge.
I'll have another look tomorrow and see if I can find it. As soon as I get any resuly I'll let you know
2000 406 Coupe 2.0
a 2000 petrol will only be readable by a dealer, or someone with a bloody expensive interface. If you want to plug something into it yourself, you'll be looking at £500 plus illegal software
coco
Post by coco »
Oooooh !!
Don't fancy either of those, maybe I'll leave well alone
Col
2000 406 Coupe 2.0
carsten0
Post by carsten0 »
I have no trouble whit reading my 406 1999 HDi. I use a U581 and it reads fault codes and live data:-)
nutski
Post by nutski »
carsten0 wrote:I have no trouble whit reading my 406 1999 HDi. I use a U581 and it reads fault codes and live data:-)
Isn't that a submarine.... :cheesy:
What is a U581 though?
*edit*
I found what it is, looks like it does the same as my ELM323/laptop combo
1997 2.1 TD Exec (Sold)
1997 3.0 V6 Coupe S (Sold)
2001 406 HDi 110 GTX (Sold)
2002 406 Coupe HDi SE (RIP)
2001 406 Coupe 3.0 V6 SE
2003 406 2.2 HDi SE
nutski wrote:Isn't that a submarine.... :cheesy:
Cheap too! (Good job it's not U235)
carsten0
Post by carsten0 »
That's pretty cheap :shock: (shame about the 40 quid postage to here and the import tax they slap on anything from evilbay now :( )
Hey, if this thing reads a '99, will it do the whole lot? (Or is that impossible?)
carsten0
Post by carsten0 »
I dont know that. But I have tried it on a 2006 Opel(vauxhall) Corsa and that worked. I have also tryed it on a 2006 Vw Transporter but no go. Dont think i works on VAG cars. I works on a 1996 Ford escort 1,8
carsten0
Post by carsten0 »
