Just when the wife's gone solo in the Pug (W Reg 110 HDI) and I'm down in High Wycombe, she's reporting a very brief bleep from the warning system and an equally brief flash of the battery warning lamp, happens a few times within 3-4 miles of starting her journey. Had a new alternator fitted recently, so not really worried about that and I'll check the voltage readings tomorrow morning after fighting my way back home to North Yorkshire tonight. Could this be an indication that the battery is on it's way out?
Cheers
Tim
BATTERY WARNING LIGHT
Re: BATTERY WARNING LIGHT
I wouldn't have thought so if the engine's running at the time.
Iffy connection on the alternator?
- Site Admin & Mad Biker!
Maybe a bad earth/corrosion in the under bonnet fusebox/cabin connectors in the footwell?mjb wrote:Iffy connection on the alternator?
- Location: High Wycombe during the week, North Yorks at the weekend
Gents, many thanks for your replies, I looked at the various bits and pieces you pointed me in the direction of but coudn't find anything wrong and typically the car would seem to be behaving itself at the moment
Thanks again one and all.
Tim
Tim
Mine did exactly this. Changed the alternator snake belt and no problems since. Happened just after a new alternator. Should have done the belt then but it looked ok.
2003 HDI 110 Rapier Estate
1999 306 1.8 petrol.
