Hi Folks,
Quick question. I noticed recently my multi function display unit has dimmed quite dramatically in comparison to the usual brightnes it has. It is still working to an extent but as soon as it starts to get dark, it is impossible to read. Any suggestions for what I can do fix this or if it is fixable?
Cheers
James
multi function display problem
- Site Admin & Mad Biker!
Re: multi function display problem
Welcome Chuck!
It's probably the bulbs gone; if it's a D8 carefully lever the display out & you'll see two of them in the top; they're the usual dash jobbies.
cheers for advice. mmmmm one question, what be a D8? I am ceek with cars, im only learning
D8 is 1996-1999, has a radiator grille like in my signature
D9 is 1999-2004, has a mesh grille
If yours is a D9 you need to unclip the panels either side of the display, unscrew the 4 torx screws, then pull the display out to get access to the 3 bulbs
nice one thanks. Its a 200 model. I got he panels off the other day but i am havign a bit of difficulty getting the screws out as they are slightly rutted. Any ideas the cheapest place to get bulbs for it ie is it a scrappy job or would it be cheap enough to buy them somewhere?
oh and one more question..... couldnt be one of the fuses could it?
Ta much
Ta much
