hi my D8 406 has started to make a clicking noise like a solanoid /motor is getting stuck, it used to do this about 6 months ago when i turned the recirc button off to go to fresh air it would click about 6 times stop reset and start clicking again
In the end i just left it on recirc to stop it clicking but now its doing it on recirc as well and its driving me mad
If anyone has had this problem or knows how to stop it please let me know many thanks ALAN
It is a common problem that starting to creep into the D9's now I think but most just open the damper/flap over the fan unit and disconnect the electric motor.
The plastic teeth on the motor/flap wear and start to slip.
Make sure you leave the flap 'open' to fresh outside air otherwise you'll steam up. You can view the flap position from the top by removing the pollen filter but access to the motor is from the passenger footwell.
Thanks for the quick reply welly i didnt even know my D8 had a pollen filter lol found it this afternoon after reding up on here YUCK !! dont think thats been changed in a long time, years even it was minging LOL.
Will have ago at that flap a bit later see if it stops clicking many thanks ALAN.
robb wrote:have sent PM I just unplugged the bugger
not got PM robb?? but how easy is it to get to to unplug it? are we talking heater motor out or can you access the motor, as i have pulled the flap open which has stopped it clicking, but can still here the motor running which needs to be turned off now
many thanks ALAN.
Sorry alan dont know where the PM went .All Id id was take out glovebox and inner shroud and unplugged the motor above the heater blower didnt touch any flaps and my aircon still works
