I've just fitted cruise control to my 406 (p*ss easy job, how to guide to follow, even got the workshop supervisor at the dealers to enable it for free, he was curious about if this could be done). The system works a treat, but there's no warning its on and working. So I was curious is there supposed to be a warning light on the instrument panel, or a caption on the multi function display to let me know its on, like most other cars I've driven with cruise fitted?
Its got COM2000.
Is there a warning light for cruise control turned on?
'02 406 2.0 HDi Rapier Estate, now with added cruise control!
Re: Is there a warning light for cruise control turned on?
My Coupe has it factorry fitted and the light is down by your right knee - by the switch - useless!
I retro fitted to the Berlingo and there is no warning light on that
2000 406 Coupe 2.0
2004 Berlingo 2.0HDi
What switch by your knee? the only one by my knee is the headlight level switch.
Mine has it as standard.(2003 Hdi est)No warning light or anything to say that it is enabled/disabled.
2003 Hdi Est SE
- welshviking
no warning light on mine either 2002 executive
2002 D9 406 EXECUTIVE HDI 110 BHP SAT NAV, CRUISE CONTROL, HEATED LEATHER MEMORY SEATS ETC ETC
So it looks like everything is fully operational, thanks.
Good to see that it all works Eviltwin.
This is my first car with cruise control.I could`nt be without it now.Its so good & easy to use.And its great when i`m towing our caravan.It makes long journeys so much better,being able to move your feet around.
My Mum got a Sabb 9-5 Aero 2 yrs ago with cruise.Took me a while to convince her to try it.Now she could`nt live without it
.The 406 system is simple to use compared to the 9-5`s,but the 9-5 has a light on the dash to tell when it is in use.
2003 Hdi Est SE
The 2 features I wanted in a prospective new car before i got the 406 2 weeks ago were (besides turbodiesel and an estate with a big boot) climate control, and cruise control. I'd had cruise before, and knew it's a must have if you do any long distance routes, so it was very important to me that the car have it already, or be able to be retro-fitted with cruise.
After figuring out how easy cruise was to fit on a diesel model, through some light net trawling, I went for the car I'm now running and ended up fitting the cruise myself for less than £50.
