d9 indicator stalk
stevemc
d9 indicator stalk
Post by stevemc »
my indicator stalk has died ,it keeps putting the n/s indicators on by itself,my car is hdi lx,without front fog lights, do i have to get a stalk without
the front fogs on it or will either stalk work thanks
jasper5
Re: d9 indicator stalk
Post by jasper5 »
I had the exact same problem on my 406 before I sold it, it's very common.
It's called a COM 2000, do a search for COM 2000 and you will find loads of info about it.
Early D9's don't have the COM2000 - it came in around 2001 IIRC
But would the COM 2000 work on an early '99 D9 - i.e. can it be retrofitted to a car that did not have one in the first place, and if so, how easy is it to do?
I think you'd need a similar vintage BSI
... & multiplex wiring
You'd want to fit a com2000 to a car that didn't have one? How about a dmf and a fap while you're at it?? :shock:
I'd imagine either stick would work, you'd just have some pins left over on the connectors.
stevemc
Post by stevemc »
just brought a new stalk from europarts ,lucky for me its not the com 2000 unit,but the earlier one £45 inc vat thanks for your help
