changing the wiper stalk
petecolli
Post by petecolli »
Hi all how easy is it to change the wiper stalk on a w reg estate :!:
Has any one got any pics or a guide on how to do it.
Cheers
pete
Wreg 2.0l estate petrol
Re: changing the wiper stalk
Depends if it's multiplexed or not. Changing the non-multiplexed stalks is a piece of cake - just unscrew the steering column cover, unscrew the stalk, and swap 'em. There's a HOWTO on changing the multiplexed COM2000 stalks though - I think the steering wheel needs to come off to do that
petecolli
Post by petecolli »
whats the differance :?:
mine has the auto wipe and the push in button on the end on it to chang the display.
cheers
Sounds to me like a COM2000. They cost about £140 and you have to take the steering wheel off to change them, the older type cost more like £20 and can be changed without removing the wheel.... :oops:
Such is the cost of progress eh? :roll:
Post up a photo of it Pete :)
When you indicate does the clicking sound like a flasher unit or an electronic noise?
Hold on, W reg (is bluddy meaningless to me now!) would make it a 2000, should be pre-multihex. I don't think they sold many without automatic wipers or the button (even if it didn't do anything...).
petecolli
Post by petecolli »
teamster1975 wrote:Post up a photo of it Pete :)
Hi its just like a ticking noise from flasher unit i think.
This is a link for the pic of the stalk. Sorry can't work out how to put a pic up on here :oops:
http://i246.photobucket.com/albums/gg93 ... 268_o1.jpg
Ah you're OK, that's the old (non-multiplexed) type.
petecolli
Post by petecolli »
DaiRees wrote:Ah you're OK, that's the old (non-multiplexed) type.
Thats great :D
Does the haynes manual explain how to do it as i'm waiting for one to come in the post.
petecolli wrote:Does the haynes manual explain how to do it as i'm waiting for one to come in the post.
I'm sure it does. It's really a piece of p1ss job Pete :)
One little tip; release the height lock on the steering column & pull it out as far as it will go!
petecolli
Post by petecolli »
Well i changed the wiper stalk (you were rite teamster1975 was a piece of p1ss) hopping it would solve the problem i had with the front and back wipers not parking correctly but it didn't.
I've changed the front motor and the wiper stalk but it's still the same :x
Don't know what eles to try :?: :?: :?:
Any body got any idea's
Cheers
pete
Parking issues are usually earthing problems but I'd think they are earthed separately :?
