Right, next lot of differences to check!
Put the cluster from a GLX petrol in, all the normal stuff works (glow plug, engine, stop, brakes, etc) but now i have the oil gauge to the left aswell.
Is this gauge a combo level/temp unit, or is it just a level gauge? (wifes 206 was a combo, mates 406 d9 is just a temp)
From memory the level gauge is in the sump in the hole above the drain hole. Is there an oil temp sensor? (if it's a temp gauge that is!)
Also, can i hybrid the speedo/rev counter gauges into the newer conslole, my xud doesn't rev to 8k and i'm pretty sure it won't do 130mph either! (but i'm an awkard bugger and want to keep the central fuel gauge
Fitted my fogs today, piece of cake to get them in, just take the lamp holder off the back and they both went in under 30 minutes. Is it me or are they a bit loose with them only having a bracket on the bottom?
Last question! (honest!) The relay to run the front fogs (the black oblong one), what does the black oblong relay next to it do?
Cheers
2.1td exec estate.
